- Joined
- 22 Aug 2006
- Messages
- 7,062
- Reaction score
- 1,180
- Country
Obviously! and Absolutely, but it shows you what's worth checking. The Filters are useful to remove anything with very low or very high volume, or anything too small.A scanner doesn't tell you everything, you still need to go through the stocks it lists and I typically see reasons to rule a lot of them out.
Sometimes you can spot a "buying program" eg where something has gone up X% in a minute, 5X% in 5 minutes, 15 X% in 15 mins etc. Those can run all day.
There are Gap scanners too, useful for the small cap gappers - which can give huge risky rises. Cherif on TTV is good with those.
@kingandy2nd there are ""rules"" for those small cap gappers. It's more of an art than a science to pick which ones are usable. If you look at the old TraderTV youtubes - they're all up there, for the time of day (4pm ish iirc) when CHerif is on, he often goes through his own rules.
He wants things which are (iirc) 1) higher than in the premarket, 2) above VWAP. Then he waits for a pullback , always. You have to look at the SPREAD which can make it unusable. The change per 1 minute candle* can be alarming as well. This is where T212 is too slow really. TTV's price moves about 5 times as often - every second or so sometimes.
*that's where say, the price is going up 1% a minute but each 1 minute candle is 10% tall. You have to grab the price low in the candle. The spread has to be tight enough to allow you to do that. If the volume is high enough the spread will be tight.
Practice. When the ducks are in a line you can get 20% move in a few minutes. T212 say they don't allow this practice but they haven't warned me for it yet. Better platforms are available, but watch for fees.
usually they go back to 0 on the run, be in day, week,... Usually you can't Short them, unless you short them early, X-1 on the way up, while you're Long +2X. Close the +2X at the top and sit and watch while the cash ticks on on the fall.I'm still in it and it is well down.
Tip: Earnings Results are dangerous to trade around. The results can be one way and the stock goes the other - often both ways in the first minutes after announcement.
However, if a stock is one with positive interest, the price will go up before the announcement. 3-4 weeks out is a good place to start looking for dips to buy.
SOFIs results are Monday so I checked,:
there's nearly 30% there. It probably won't move that much on the announcement, so take the profit and go. I must admit it can be fun to have $100 of the thing through earnings. Whatever the price does you can react. If it dips, it'll come back so there's a rise you can use, etc. If it goes straight up sell because it might go negative in a few seconds time. Selling 2/3rd leaves you something in case it goes on up. Sometimes they hit max around (our) midnight.
