stopcock outside not turning off
you want air to get into the test jar
you are trying to produce conditions that encourage rust
if the inhibitor prevents it, then you know it is working.
Corrosion inhibitor only protects against electrolytic corrosion though doesn't it, as you said metals rusting metals, ie steel being rusted. - not against affects of air being drawn down the vent (air getting in) or fresh water constantly getting in (pumping over)???
you can buy an inhibitor-strength test kit
but before they were invented, the makers of inhibitor chemicals used to recommend the nail-in-the-jar technique.,
It's cheap and easy.
