If I need to do a back up, though, I dont think I have anything to do a back up with,
In that case you can't take a backup, which means that you risk losing files of which you have only one copy.
Apart from the pictures there is nothing, if possible would it be possible to put them on a disc or sd card.
The main thing is the sky wireless router,as I am on xp now, not sure if it works with vista,till i phone sky or find the book for it, I will also need to find the disc, unless I can back that up ,but quessing that may not work with vista.
Isuppose I need to get something proper to do a full back up before I install the vista
Iwas thinking an external harddrive or something, can you advise anything to buy,just for that.
When I do copy over to vista will these faults transfer with it though.
I don't know what "copy over to vista" means. Do you?
when i do so, before I remove the xp and copy the files from my harddrive, when I install the vista, and reload my files back on to the harddrive ,I suppose any faults I copied will also be put back on to the harddrive again
Thats why I went into the registry to find the pci device
And I was lost in there
Did you also read the advice that discourages you from editing the registry?
I read the advise, I looked in there just to see if there was more info onthe pci device
I had no intention of editing anything
I did note i think it is called Napstar in there though,
the problems including the loss of sound occured about the time i loaded that.may be a coincidence though.
i expanded that and there was an option to delete the key, i was unsure what they meant by key,
I would like to uninstall that but did not see it in remove programs
i could not find active sync in remove prog although it is in the start menu I would like to uninstall tht also
In the add/remove prog
I have uninstalled things i know i loaded, however" Egog games"will not uninstall there, this was loaded off a cd but never worked for some reason it asks if you want to remove it, says set up status,
then maintenance complete , but is still there, unlike the others that uninstalled and went
Thanks for the help,I have to go out now though.
I will look back asap
If you feel I should take the computer somewhere and get it serviced, Iwill do that.
