After the phone was plugged in and did not load i think
i think i cancel it other wise the other button starts it again.
usually i just cancel before it starts
toshiba a100
The new hard drive has no info, so i am reading up what to do with it
Right, OK, I've been reading - again. I think that the drivers for the old phone haven't loaded and your computer is looking for a mobile device but can't find it because it's only partial install.
When the Hardware Wizard comes up, just follow it through for it to install the drivers for the phone. Once it's installed, you can uninstall it, but I think it's only got a partial install and that's why it's causing so many problems.
The reason I asked about how you ended it, is apparently (dunno if it works or not) but if you let it run, fail and then click finish at the end, it shouldn't come up again.
The two things on the startup menu I was talking about are looking to start up from your D drive, which will be your DVD drive - and since you probably don't have a disc in your D drive all the time, it just seemed like sense to take them off.
I'm now gonna sit here with everything crossed in the hope that doing a reinstall of the phone software works.
