Hi all
I have a floor mounted Thorn Emi boiler, open flue, vented system which has started doing some strange things. Firstly, when the boiler fires up in the morning, air noises passing through both the boiler and the pump can be heard. This eventually passes through into the rads with me having to bleed the highest rads in the house every other day. The noises from the boiler normally goes away after about 20mins of the boiler operating.
Next, when the system turns off on the time switch (with the boiler still operating) a 'rushing' noise can be heard in the vent and cold water feed lines. I simulated this last night and observed the following in the header tank.... when switched off, the water level in the header tank drops by about 5mm..... when switched back on, the water in the header tank rises by the same amount, being reverse fed by the cold water feed pipe!!.
There was no evidence of any water coming from the vent line into the header tank. Why would the water back feed via the cold water pipe and not through the vent..? Does this mean that I have a restriction in my boiler?
Going back to the boiler, I have progressively over the years had to reduce the temperature on its thermostat due to kettling noises.
I am at the point where I think the boiler is due for a change.
I was going to try and descale and flush.... but am I delaying the inevitable ??
Any advice would be much appreciated before I have to remortgage the house to pay for a new boiler!!
