Hi all,
I've had a submersible pump in a small hole in the floor in our cellar for just over a year and last week it just suddenly started tripping the fuses.
It's just a normal 240v puddle pump (http://www.clarkeservice.co.uk/manuals/submersible_water_pumps/psp125.pdf) and it's plugged into a socket on the main ring.
At first it was blowing the ring MCB (Square D C32 RCBO) and by the time I managed to get down there to have a look, it was going beyond that and blowing the 3-phase RSD (Square D 80A RCCD) which supplies the entire section board that powers our 3-phase plant, room lights and the relevant socket ring.
Fortunately I had a spare pump, so I just switched the pump over and everything's fine now, but in order to return the pump for inspection they're asking me to tell them what the problem is with it first which seems a little strange to me. I've got an NVQ level 2 in electrical engineering and my 17th edition, but I don't have the experience to be able to guess at what the likely problem is, but they're saying because we're a commercial premises they want to know what the fault is with the pump before they'll give me a postage slip for returning it to them. I can only assume they must have different places for returning different faults to, but I would have assumed electrical is electrical...
Regardless, I'm a little perplexed so just wondered if anyone could even give me a brief idea of what might be the issue and I'll just pass that on to them and hopefully get it sent off as soon as possible.
Cheers!
[EDIT] I should probably add that it blows the breakers as soon as the socket is switched on even though the internal switch on the pump is in the off position and I've tried it in a different socket to make sure it isn't just the socket. I'm guessing it's somehow developed a short, but I realise it's not always as simple as that hence I'm here and asking.
Cheers!
