You won’t need to rip out the old cable, not quite that drastic I’m pleased to say. I’m assuming you don’t use the single socket as its now in the cupboard; all you need to do is remove it and replace it with an un-switched FCU like the one I showed you in the link. The single socket will be fed by one or two mains cables, these need to connect to the "supply" side of the FCU, your black extension that’s chased into the wall will connect to the "load" side of the FCU, it will then be safely protected by the fuse in the FCU which should be of the same rating as the one in the plug you chopped off. Not sure what you mean about the 4 gang sockets, they are fine as they are and you just need to change the single socket to an FCU to make it all safe.
Again not sure what you mean about the TV, is there a join buried in the wall and if so how has the joint been made? Where is the TV powered from, is it plugged in somewhere behind the AV rack in the corner?
With the fish tank do you mean there is a socket on the floor under it or on the wall behind it? How did you connect the 4 gang to the socket, is it plugged in or hard wired to the back like the bedroom socket?
I also want to clarify that I said it’s a "potential" fire risk, it could all work for many years without a problem but it’s better to be safe than sorry and put it right before anything could go wrong.
Aside from that both installs look amazing, really like the colour scheme in the living room too and the AV rack is same style as my uncles, very nice indeedy
