sunvic 207 xls
7 Dec 2010
Hampshire
hello i installed a sunvic 207 xls controller for my back boiler it worked for a while then stopped, the screen shows no reading, have i blown the controller or a fuse some where i cant find ,the power box fuses to the house are all working . thankyou
Was the new prog an upgrade or a replacement for a dead one?
How long is a while, in your house?
hi mick, its been on for the last yr, it was changed because the timer was broken on the old one, but today i changed the thermostat in the hall wired it correctly , it all went well then when i went to change the settings on the program from hw to ch it just disappeared,so im assuming that the programmer was not wired correctly, so its tripped somewhere or the box is knackered, thanks for the reply,
This statement makes me think, maybe you didn't wire it correctly.
What make and models of room stat did you and now have?
