Sunvic Select 207 ch/hw Programmer Replacement Problems
3 Nov 2016
I had an old Sunvic Select 207 (not the 207XL) controlling my heating and water. It started making loud clicking noises when both water and central heating were on together, before starting to click on each individual program, so I replaced it with the Sunvic Sunpro 2000 which is supposedly is a direct replacement and fits the same backplate and wiring.
However, when I put both water and central heating on the flame in my boiler goes out and so nothing is on.
If I put the heating on its own that works fine.
If I put the water on its own I have to scroll through the program opitions twice of 1, 2, 3, on and then back to off, 1, 2, 3 to get it stay on.
I reconnected my old controller, despite the clicking, just to check what that did and I can get both the water and heating on individually together.
I was wondering if the Sunpro2000 is indeed a direct replacement Select 207 or maybe its another issue?
I don't have a room stat to control my heating. The controller is mounted in my airing cupboard and the thermostat option isn't activated on the new controller.
