What happened?It can cause an overload if the outer housing of the element splits and allows current to flow to earth through the water. This is something I have genuinely seen happen.
So regs say an immersion cable need not be protected by fuse or mcb? Foolish not to. It is foolish not to protect the immersion and cable.It was causing the OCPD to operate after a few minutes. The L>N part of the element was still intact and consuming 3kW as normal, but there is also the additional load of the water conducting L>E.
BS7671 does not require an immersion heater (or any other load) to be protected by an over-current device, since that is beyond its scope. as often discussed here, if any load (immersion or otherwise) requires over-current protection, that should be provided within the item concerned.So regs say an immersion cable need not be protected by fuse or mcb? Foolish not to. It is foolish not to protect the immersion and cable.
Ok.It was causing the OCPD to operate after a few minutes.
Ok.The L>N part of the element was still intact and consuming 3kW as normal, but there is also the additional load of the water conducting L>E.
I suppose a flimsy element wire would do similar to a very small extent but even that (well made?) electrode only got to 1kW in, for it, an ideal situation.If you are not familiar with electrode boilers, have a look at big Clive’s video on the subject. It’s very interesting.
This happens:What happened?
Presumably like you, my guess would have been that it would not have been possible for more than a (once only) very brief period of time - for part of the element it would be equivalent to supplying a "230V" element with ~460V, in which situation I would have expected it to have 'burnt out' pretty quickly.Ok. So, that is 12.5A for the normal consumption of the element and 12.5A (also 3kW) through the water which would mean that part of the element was also carrying the 25A. Is this possible for an element which is designed to get hot (70° or more) in normal operation at 12.5A?
A fairly high proportion are, these days, presumably RCD-protected, so we wouldn't get the chance to see if what RF described might happen if the fault were not cleared in these cases.Why don't all immersion heater do that when the the casing splits?
That does sound like a credible alternative explanation. As above, I would not have expected the initial part of the element to repeatedly survive double it's normal operating current for appreciable periods of time.Are you sure the element was not just bending and causing an earth fault after a few minutes.
... to which I possibly should have added a reminder that "double it's normal operating current" equates to "four times the normal power dissipation in it"..... As above, I would not have expected the initial part of the element to repeatedly survive double it's normal operating current for appreciable periods of time. ...
Kind Regards, John
Double current through the 'first segment' of the element will result in four times the power dissipation in that segment of the element as would be the case when 'normal' current was flowing through it.Only if that double current is flowing through the whole element which would require a 480v source. If it is through part of it that part will dissipate 4 times the power.
You did, and that is clearly the situation we (including myself) are talking about - so why your preceding sentence which refers to a situation which we are not talking about?Isn't that what I effectively said: "If it is through part of it that part will dissipate 4 times the power."
