I can understand the bottom one - although, as you said previously, that 'safety' function could be performed by the immersion's own thermostat. No harm in 'belt and braces', though!Top sensor used to take priority 1 reading, then middle used and compared to top. Bottom used to oversee and has a high limit set to shut things down if it goes crazy it gets stuck on. Basically at draw off is most critical temperature and it uses a high accuracy probe to grab that data to react fast.
However, what is the result of the 'comparison' of the middle and top temps? Will that sometimes result in the temp at the top (at draw-off point being raised to a little more than you actually want (for the draw-ff temp), because the temp in the middle is a little 'low'?
Apologies for all the questions, but I'm just trying to 'understand'!
Kind Regards, John
