Switching from Standard 2 Gang one way light switch to Wifi Smart Light Switch
So, I'd like to....
Three equivalent ways of saying that are
  • "Because of that I'd like to...."
  • "As a result I'd like to...."
  • "Therefore I'd like to...."
Please think about why you should start a sentence with "So...."
swap my existing 2 gang light switch in the lounge (which operates wall lights and central light) to a wifi smart light switch that does the same.
Yes, but why??
I think if you look at the pictures that I have neutral wires that are capped at the back of the backbox. Therefore, I was thinking (but would welcome knowing if this is right), that I run a neutral cable from 'N' on the new switch back up into the collection of capped neutral wires at the back of the back box (or do all those neutral wires do different things?). I then take away the little cable that joins the 2 holes marked 'Common' on the old switch. The 2 wires which are left in the 'Common' holes on the old switch both go into 'L' on the new switch and the remaining 2 brown wires in holes marked '1 way' on the old switch go into L1 and L2 respectively.....
You'll need to put one of the blues into the switch, along with a wire from there to the connector block.
Yes, but why??
I suppose it will save him getting off the settee to switch the light, he just has to grab his phone.
In my experience though the phone will be on charge in the kitchen so he will still have to get off the settee to get his phone.
Free electrical advice with grammar lessons thrown in, what more could anyone want?
You should not be giving instructions to people to stick this wire in that hole. You should be encouraging them to learn about electricity before they start fiddling.
He clearly knows exactly how it should be wired - I was pointing out a mechanical problem regarding that 4-port push-in connector.
But well done for behaving, yet again, in a childish and pathetic manner, and showing, yet again, just how useless you are at this. It's quite amusing, actually, to see someone so clearly unfit for purpose taking care to make himself look even worse, just in case his reputation does have any further to fall.
The please explain what "So" was linking to when used as the opening word by the OP.
The same thing as your "Because of", "As a result of" and "Therefore" were all linking to.
... and, if you accept that "because" is a conjunction, do I take it that you were taught that it was correct to start a sentence with a conjunction?
Kind Regards, John
Which was?
What would it be joining?
Do you see any difference between a gratuitous "Because of that, I'd like to swap my existing 2 gang light switch in the lounge ..." (where 'that' is undefined and unknowable to the reader) and "Because I have mobility problems I'd like to..."?
Consider these:
The floods had take the bridge out. {So we had to go the long way round|Because of that we had to go the long way round|As a result we had to go the long way round|Therefore we had to go the long way round}.​
They all make sense - in each case the reader knows what the 'So', the 'Because' etc refer to.
But gratuitously starting a conversation with "So we had to go the long way round" is nonsense.
It's more a case of basic meaning than grammatical constructs.
And I really cannot see what discussion is needed - I suggest that every time you see an opening sentence of the type "So, I'd like to swap my existing 2 gang light switch..." you try a substitution, and imagine it begins "Because of that, I'd like to swap my existing 2 gang light switch in the lounge ..." or "As a result, I'd like to swap my existing 2 gang light switch in the lounge ...".
If it doesn't make sense like that, it doesn't make sense with "so".
