I'm not sure how to correctly fit the black half-sphere washer that seats onto the first chamber in the pan. I can't work out whether in operation the washer slides up/down the pipe it fits over, or is intended to remain fixed.
Should I simply fit it at the extreme lower end of the pipe, and then lower the cistern slowly back onto the pan, relying on friction to not push it up so far up the stem that it no longer seals? Or is it intended to tolerate slight gaps underneath it, because the water pressure above it (and the vacuum below it if working properly) will re-seat it if necessary when it flushes?
I can't find any description of the recommended installation technique anywhere and am not sure whether the shaft of the pipe should be lubricated so the washer can slide. Please can someone (with a long memory) advise.
Thank you.
Thank you.
