Remember with the obsure boilers repairs/maintenance can be problematic. I include Viessmann/Atag where backup is poor.
Manufaturure warranties are often void due to installation issues, poor system design and lack of servicing.
Don't forget the cost of maintenance...the initial install price is only part of the cost and some boilers have horendous parts prices eg. Viessmann.
Just remember that when a combi breaks down (and it will) you have no hot water. A cylinder has the immersion heater backup.
Most installers have little understanding of system design and often fit system boilers for simplicity.
Therefore (since the installer won't) ensure the boilers expansion vessel is of sufficient size (and they are often too small and an additional one will be required) and that the pump is capable of circulating the water (again they are often undersized due to modern heat exchanger design).
Most system boilers are really only suitable for smaller properties and but manufacturers produce them with too high Kw outputs for the vessel/pump. You are also lumbered with the boiler manufactures vessel, pump, safety valve etc. so that can be a much higher expense at repair time.
IMHO with the larger property it's better to have these components seperate to the boiler and use a heat only boiler.
