call it £5k worth of reference angles and other lab grade equipment to have it really perform 100%
To check the slider runs true to the arbour all you need is a dial guage. About £50 quid.
Then the blade can be checked for accuracy with the dial guage also and if the saw unit is correctly fitted on its mountings it will be spot on.
Checking its cutting square involves cutting about 6 sides off a small sheet and checking the last cut off with digital calipers. Then fine tuning the fence stop for 100% accuracy.
No need to send it to the lab.
