I acknowledge that the title and the subject sounds a bit daft and is likely to get me some flak, but bear with me I'll explain what I'm trying to achieve.
I'm leasing a old barn and am trying to give it a bit of a cheap facelift and make it into a photography studio for myself. This involves a couple of stud walls for changing room, office and kitchenette. There are currently 3 separate double-sockets in the barn, with each terminating on a dedicated 16amp MCB in the CU.
My first thought was that I will run an extension lead from each socket (as they are not conveniently located) to power the items in each area (fridge, kettle etc). However, now the stud walls are built I have an opportunity to put in some dry lining boxes and socket fronts, which lets face it look much better than trailing extension leads.
The question: Would I be committing some heinous crime if I were to wire in each dry-lining box socket with flex cable and a 13amp fused plug? Then I can just plug them into the existing sockets still (which will be behind furniture) but the presentation at the appliance end is much neater.
It's essentially achieving the same thing, however instead of an extension socket at the end of the cable it's a dry-lining box and a socket. Does that make sense?
Thanks in advance.
Thanks in advance.
