The 'good workmanship' regulation is an incredibly vague 'catch all' one which BAS wheels out whenever he personally does not like something but can't think of any other specific regulation which it contravenes. My grandfather would have said the same - a lot of tutting and an assertion that "unprofessional = poor workmanship"So I would very much be interested to hear what everyone says on the subject of the 'good workmanship' you mentioned and if I would be in breach of the regulations on this basis. So far it appears only yourself has the opinion that I might be. Anyone?
As I said before, what you're proposing is neither 'nice' nor 'professional', and limits you to 13A on the socket(s) fed from one plug, but (provided the cable is not a trip hazard, and that all the wring done competently and safely!) it is no less safe than plugging anything else into a 13A socket - so I doubt that, even though they might not 'like it', either, many people other than BAS would seriously suggest that it contravened the intended spirit of the regulation about 'good workmanship' (provided everything was wired competently and safely!).
Having said all that, it is quite probably virtually as easy, and maybe even cheaper, to 'do it properly' (and then virtually as easy to 'undo' when you need to), so I'm not really sure why you're adopting this approach.
Kind Regards, John
Thanks again for your detailed reply. Like I've mentioned in my post above, I take a good look at everything and decide if it is indeed the right approach to adopt.
