The heat pump trial
Does it cause that weird twitch you've developed?
No it heats a house in conjunction with a gas combi as potential back up
A sort of hybrid type system
Property is probably 70s built (?)
Are you asking me if i know when your house was built?
No
My house was built in the 50s
I am telling you that the house tbe ASHP was fitted in was built in the 70s
Is your twitch interfering with your ability to read ??
Heating works quite well all rads are over sized
Additional insulation in the prop has not been done
Quite well meaning the bloke is happy ish
Some of the prop is heated via under floor heating
Friends recently renovated their restaurant completely, including the installation of a reversible air source heat pump system to the three (public) rooms of their restaurant. It cost about €20,000, but it works well in winter and summer.
Two whole sides of their restaurant are single glazed (it's a corner location) shop style windows. Obviously there are large volumes of air extraction going on in the kitchen. Domestic apartments above, but I would imagine little to no insulation in the floors or the other walls.
They report that they are content and comfortable with the system.
I think if I had lashed out 20 grand on a system that didn't work, which I wouldn't be spending anything on heat pumps and which don't work, I would be reluctant to admit that I had paid out that much on a pile of junk.
Similar situation occurred in a prop down this way I visit
There out lay was 250 grand !!! Best thing since sliced bread they say :ROFLMAO:
It’s carp
No
I do not have a twitch, but it seems all that hanging on the telephone is making you irritable.
Relax and enjoy the ride...have another piece of cake.
It's dee-lish.:p
It's dee-lish.:p
No you seem to have a twitch as you come across as slightly unstable ?
Are you on medication that could cause it ?
You need to relax may be ? And have another drink ??
Do you own a parrot?
All i hear are echoes of what i've just said?:unsure:
No I don’t do you ?
The echoes are in yer head ? A typical symptom of having an empty space :ROFLMAO: between your ears may be ?
No I don’t do you ?
You're the one parroting my posts.
I bet you can't remember where this even began.
Are the echos still there Do they increase at night ?
Does it interfere with your sleep ?
Has anyone mentioned the noise these things make with a giant fan running 24/7 in a metal box facing your neighbour. Now imagine a whole street full all back gardens facing each other left right and behind. Vibrations from the unit ? / a terraced house row of units transferring through the house manifesting themselves as a harmonic frequency triggering migraines white noise - unable to sleep.
Just spit - balling but who knows.
Yes that is likely to be an issue down the line
If I recall there have been cases ?? Of heat pumps having to be moved ? Due to noise and complaints ?
