The heat pump trial
I am trying to work out the general principle, here. They say a modern gas fired power station is 60% efficient. Does that mean 1kWh of gas produces 0.6kWh of electricity? And then, with a COP of 3, the heat pump would turn that 0.6kWh of electricity into 1.8kWh of heat. Whereas a modern gas boiler might be 85% efficient, so 1kWh of gas produces 0.85kWh of useful heat. Is this roughly correct?
Probably been mentioned before, but is there merit in having a dedicated "Green / Eco" subforum on DIYNot?
Certainly a big enough field in its own right, to merit one.
Has anyone mentioned the noise these things make with a giant fan running 24/7 in a metal box facing your neighbour. Now imagine a whole street full all back gardens facing each other left right and behind. Vibrations from the unit ? / a terraced house row of units transferring through the house manifesting themselves as a harmonic frequency triggering migraines white noise - unable to sleep.
Just spit - balling but who knows.
It won't be any different to air conditioners in hotter climates. It hasn't killed them all off yet.
You've forgotten where the link is, haven't you?
Alzheimer's is a terrible thing.
Get it checked out.
Do you get them echos in your head at night
Followed by the illusions of parrots ?
Are you a heavy drinker ? Or do you take some other substance that may effect your mental well being ?
Agreed Alzheimer’s is a horrible thing and you should not made light of it ?
Have you walked to the toilet and when you got there you forgot why. You are there ???
