D
Deleted member 221031
How does that have an effect on the camera ? You’d think China would be able to make a decent camera for the job by now.It was 10 years ago on the far side of the moon, also tracked by NASA.
No idea, it was just a comment. What camera did they use?How does that have an effect on the camera ?
I’ve no idea. My point is the picture quality is shocking given the year.No idea, it was just a comment. What camera did they use?
Cheers for that. But still, why would the landing be in black and white, the module looks as bad as the Apollo ones.Some hi res photos here.
Chinese photos show moon's surface in vivid detail | CNN
China has released hundreds of high-resolution photos taken by its Chang'e-3 lunar lander and rover, showing the moon's surface in vivid detail.edition.cnn.com
How does the Rover get better quality.High quality video signal needs high data rate.
High data rate needs more power.
Sending signal further needs more power.
Colour needs more processing chips and more data which needs more power.
High data rate and sending video a long way into the sky to moving orbiting repeater spacecraft needs a lot more power.
Lunar module does not have a lot of power as batteries and solar panels are heavy.
Hence 'live video' from moon is intentionally selected to be lower quality (sometimes even black and white) as there is limited power and it is a long transmission distance.
Still Images are typically high quality as they contain the information they want and so are buffered and then sent with slow (lower power) data rate. But you get less images as you increase their size and quality as bandwidth (amount of data you can send) is fixed by the amount of power you have.
It's around 10x as large and a decade more modern.How does the Rover get better quality.
And you’d think they would record some in 4k ?
