Theories
Well, so far as I can see the only exotic thing about a black hole is the fact that it appears black.
All a black hole is, is a really dense piece of matter. Now, if you think about a star, that is really quite heavy, and as such has rather a lot of gravity. But, at distances that are many times the star's diameter, the gravity just doesn't seem that impressive anymore.
However, because a black hole is so dense, the gravity at many millions or billions of times it's diameter is still rather strong. So, it has a comparatively strong gravitational field. A black hole with the same mass as the Sun would only be a couple of km across, whereas the Sun is about 1 million km across (if I recall correctly).
Now, the second bit, which is the whole point of a black hole, is this gravitational field is so strong that the object's escape velocity exceeds the speed of light. Hence light doesn't escape, it appears black and so forth. Not everything gets sucked in so you get jets as well, which shoot out normal to the accretion disc at near-light speed. Not sure why exactly black holes do that, perhaps it is the stellar equivalent of dietary fibre? :D
There are suspected black holes of several billion solar masses at the core of a few galaxies, wouldn't want to get too near one of them! I wonder though, you could create a blackhole, point the jet in the direction you wish to travel, and use a sail-spacecraft to travel at relativistic speeds. Here to Alpha Centauri in no time. Of course, you would have to put up with the X-ray dose, and you might annoy anyone who lives around Alpha Centauri when you wipe out their entire population before you even get there. :eek:
Yeah, I know what they are, how do they form ?
i've got a black hole at my bank?i put money in every week but at the end of the month its vanished :confused: :confused:
they've also got one at B&Q in aisle 18 where all the plumbing bits are :eek:
ADAM!!!. .....1630 tomorrow at Dr Hoffenfeffers, you should know the address :LOL:
Hmmm, bit of a big evolutionary step from a fish to a bird...
Well, there are Flying Fish of course (I wonder if they rest on Perches) ;)
The scientists seem to contradict each other on the subject of balck holes,one minute they say it is hard to detect as no light escapes and the only way to "see" it is it's interaction with near objects. Then we are told about the jets that spew out twice as much energy as went in at right angles to it now is this a hypothesis or have they "seen" it with Hubble or something?
It all comes back to "Health and Safety"!
A wubble wubble wubble... (he says with a pair of underpants on his head and pencils up his nose)
No, they like to rest in a different Plaice. Like sailors, they often sleep in a Haddock. Sometimes you can see them all lined up in a Roe. They don't like the stress of being on their own, grouping together helps relieve that Tench-ion. ;)
