That's the by-pass pipe, running from after the pump and before the 3 port valve. We've already agreed that the by-pass valve should be left shut since there are no TRVs.Where is this pipe coming from?
He's in denial! He's hoping that if he ignores the real problem another easier-to-resolve problem will come along instead.you've already been told the prob...blockage in the cyl coil/return pipe, clear that and the noise will disappear
Fluid hammers? Cavitation? What do you mean by these expressions?There was a lot of air in the system and a good few 'fluid hammers', a decent bunch cavitation ...
So why on earth won't the thermo mixer valve cut the cold down enough to mix it correctly?
swap the hot and cold pipes on the shower
