Hello,
I'm thinking of replacing my wired Room Thermostat with a wireless one that I can move from room to room.
The set up is I have a conventional gas boiler in the Kitchen and a wired room thermostat in the Hall downstairs and a central wiring box upstairs in the Airing cupboard.
I have attached a photo of the Wiring Box. Looking at the Photo from left to right the first white cable goes to the central heating pump, the middle white cable goes to the Hot water cylinder thermostat and the right hand Black cable goes to the 3 port divert valve.
I wish to replace the wired hall thermostat with a simple temperature only wireless thermostat that I can move from room to room. It does not have to be Programmable because the boiler has a programing unit situated beneath it.
My question is does the Wired Hall Thermostat go back to the wiring box in the Airing cupboard, if so how do I know which wires they are?
Is the wiring box the correct place for me to connect the new wireless thermostat, if so can anybody tell from the Photo where I should connect it?
Many thanks for reading. View media item 59365
