Yes do have a meter
Sorry for using the Celect stat terminals in the diagram; I didn't see that you now had a Honeywell stat. 2= A; 1 = B.This is what I have done so far
Remove wire from 4 in prog and join to B in relay, also as before.
You also need to connect 4 in prog to A in relay.
The link in junction box is a short wire that joins together the 2 terminals that the old room 'stat switch was removed from. (T4 and T5)
I would ignore that; it doesn't make sense to me either!What was that about having the old thermostat turned up? even when disconnected?
D_Hailsham";p="2786658 said:kevin12345";p="2786488 said:1. Please confirm which make/model programmer you have.
2. Will the boiler light for hot water only?
3. Does the pipe from valve to cylinder get hot?
4. Will the boiler light for CH and HW at the same time?
5. Does the pipe from valve to rads get hot?
1. Danfoss FP715
2. Yes
3.Yes
4. Yes
5. No
Before I tried to fit the wireless stat every was working ok
Bye the way I have not quite worked out yet how to take quotes properly from previous posts yet.
Yes for Q3 and Q4 is as expected.1. Danfoss FP7151. Please confirm which make/model programmer you have.
2. Yes
3.Yes
4. Yes
5. No
Every quote has to start with a [quote] and end with a [/quote]Bye the way I have not quite worked out yet how to take quotes properly from previous posts yet.
Blah Blah
Rabbit Rabbit
