I found the three core and earth cable between the two way switches
had the blue wire inducing a voltage onto the yellow (outermost wire) which
was then producing a current to neutral via the LED lamp, which dimly glowed.
Other lamps would have enough resistance to block this.
I ran in another cable to replace the yellow two way strapper
physically separated from the original three core.
