Staining is often related to hair and body products which contain colouring which will stain grout, though this is much reduced with regular cleaning, mould will occur if there is insufficient ventilation, does the room have a powerful, efficient extractor fan? and unless it has and the fan runs every time the room is occupied mould will get a hold.Mould growth also likes still air so it starts behind bottles and sponges left at floor level which block air circulation.My bathroom which had good air movement had white sealant around the tub which remained white and unstained for over 20 years, a friend who I do the odd maintenance jobs for has me replacing the sealant around her bath every 6 months despite having a cleaner in 3 times and week , she had poor ventilation and insisted in stacking dozens of products along the bath edge.
As mentioned ply is not ideal and pva should never be used to seal anything before tiling.
The extractor fan (as long as it's not switched off) can easily extract all of the excess moisture in the room. The house is only 14 years old, so everything is to that spec. Cheap though. Most of which has fallen apart and or been replaced with newer higher rated items or products.
It's difficult to know exactly what the tenants have done. In this house, it seems, every single tenant that has lived there have been happy to do their own thing regardless of what the contract says. So basically I should expect the worse because as they always seem happy to do that.
So far these tenants have broken the Security Alarm and had it repaired (alledgely via an alarm company but probably themselves) including changing the security code.
I'm still waiting for a copy of the Engineers report to find out what happened.
They have painted the newly treated wooden shed in the garden a whitey cream colour.
I'm just waiting for the next thing from the Agency "oh they've done this, but doesn't it look pretty?" or "they are really looking after the property but something else has broken" comment.
This is the same Agency which before these guys moved in they sent me the contract to sign with the wrong names for the tenants on it.
I sent back the contract to tell them to correct it and they gave the tenants the keys to the house before the contract was signed. FFS.
Two whole weeks later the tenants are already in and then sign the contract with no inventory list created. 4 weeks later the inventory gets done and lamp shades were already missing. Thankfully I'd done my own inventory and the missing items were in the loft, two were already broken.
Getting back to the tiles. I think that as the tiles seem to be sound (as no one is complaining about the tiles falling off) the grout is at issue here or lack thereof. This was caused by the tenants rubbing off the grout to clean the staining. This then exposed the underlying base which made the situation worse continued with the prolonged repair period and the tenants still using the shower has made this much worse than it should have been. I will not be replacing the tiles unless I really have to. I.e. if they are not falling off.
I will make sure the second contractor is aware of epoxy grout and also make sure the area is left to dry before work commences.
The exposed area will need to be treated for any suspect mold, if it is there. So far I have not seen this happen but never say never.
Unless some other crap happens in between.
