Toilet Waste Soil Pipe Connection
Softus
However, capping off the top part is a no-no - it should be connected to a vertical run and carried up to a roof vent, unless the BCO says that you can reduce the height and use an AAV.
Do I need to do this as I aready have a vent running up to the roof from the main stack?
Softus
Maybe; maybe not. I can't answer that without knowing the layout and lengths of runs of your existing soil system.
Even if I did answer it, the work you're planning is notifiable, and the final decision about the vent/AAV rests with your BCO.
