G
Goldberg
Are you able to say where in The Building Regulations it states that a room thermostat is mandatory?It is under the building regs
I'm having a look but can't see the info anywhere, doing a search for "TRV's" within the page gives me nothing.
Can you help me out as to the where the info on the FAQ's is located please?
Of course he is able to do that, every pro is.Are you able to say where in The Building Regulations it states that a room thermostat is mandatory?It is under the building regs
You believe wrongly.I believe that the regs state that the boiler must be fitted with an interlock
No mention of any particular style of control being mandatory, just that "reasonable provision" is made.L1 Reasonable provision shall be made for the conservation of fuel and power in buildings by─
<snip>
(b) providing and commissioning energy efficient
fixed building services with effective controls; and
(c) providing to the owner sufficient
information about the building, the
fixed building services and their
maintenance requirements so that the
building can be operated in such a
manner as to use no more fuel and
power than is reasonable in the
circumstances.
No legal requirement may be bypassed.the reqirments may be bypassed
Why? Is that something that you do?Of course I may be telling porky pies.
The question was about The Building Regulations, so why would I want, or need, to refer to that?I suggest you refer to
"Domestic heating compliance guide"
Section 2.2 part f
I can't think of one single reason for reading a document that isn't The Building Regulations, i.e. that isn't the law."the minimum provisions of boiler interlock, zoning and time control and temperature control of the heating and hot water circuits as described in table 2 should be met.
I suggest you read table 2.
I have a copy in front of me - have had for years. On a technical level there's nothing greatly wrong with it. In the context of the law, and the question I asked about The Building Regulations, the DHCG is 100% irrelevant.Oh and I'm sure you'll be googling this, i'll save you the trouble as you have no clue what you're talking about.... The DHCG is a second tier document of ADL1a and ADL1b as a source of guidance in complying with the Building regulations
It isn't "under the building regs" at all.It is under the building regs
I don't need dole money on top of what your wife pays me.Isn't it time that you went to collect your dole?
I don't where you're quoting from, but it isn't The Building Regulations."the provisions of controls that meet the minimum control requirements as given in the Domestic Heating compliance guide for the particular type of appliance and heat distribution system"
Please see above.If its an irrelevant document why is the building regs referring to it
Ignoring the fact that you've invented the term "2nd tier", presumably with the aim of appearing to know something special, all of the government's guidance documents clearly state their purpose, which is simply that - guidance. They're not irrelevant per se, nor did I suggest that - I simply said that they're irrelevant in the context of a question about what's mandatory and what's in The Building Regulations.The 2nd tier document does not mean it is irrelevent but is a means of complying with the regulations, often detailing in a more 'user friendly' way.
I don't ignore the guidance documents, but they merely illustrate some ways of complying with the law.You ignore the AcOP, and chances are you f***** up on the regulatory adherence.
Yes. I have a copy in front of me, and have had for years.Have you read the GS(I&U)R's in its 'pure legal' format?
Because there are some people who can't understand the legalese.why do you think they print the guidance notes with it?
I suggest that you ask that of someone who thinks that it's nonsense.Oh, and if you find it nonsense, why have a copy?
Yes that was a mistake - in my head I wrote "introduced", but my fingers typed "invented". I apologise.
Interesting. One mistake makes me a cretin?YOU ABSOLUTE CRETIN.
As I've said, it was a typing error. I know it's hard to believe that I make them, and that I'm not perfect, but I really am merely human.So don't come on here proclaiming to have one when you obviously cant even read the 1st bloody page!
You're not quoting from The Building Regulations, or from any document that makes anything mandatory, which is what all this was about.http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADL1B_2006.pdfthe provisions of controls that meet the minimum control requirements as given in the Domestic Heating compliance guide for the particular type of appliance and heat distribution system"
Controlled services part 35
Again - not in The Building Regulations. I've never said that they don't contain things that aren't reasonable provision, but there are other ways of making reasonable provision that are perfectly legal.Oh and two final quotes for you..
"These new approved documents are more strategic in nature and rely on 'second tier' documents to provide detailed information on the minimum provisions necessary to comply with the requirements of the regulations" Section 1
"Both approved documents refer to this pulication as the source of detailed guidance on what is reasonable provision" - Section 1.3
Thats from DHCG, you know, the one you have in front of you
No, the The Building Regulations do not refer you, or me, or anyone, to the DHCG.Its saying in plain english just for you, that YOU NEED to listen to it to find the MINIMUM requirements as the building regs themselves do not contain it but instead tell you to refer to the DHCG.
