When I had a wet underfloor heating system installed, I was told that a thick thermal concrete mass was required between the UFH pipes and the finished floor. I believe I was told 7cm thick concrete mass I was only able to get 4cm in.
If all else is equal, why is 7cm better than 4cm? Why is 2cm worse than 4cm? I'm really confused.
Speaking generally, a good heating system feels responsive. If you feel cold, and turn up the heat you want to feel that heat right away. Same for when you turn down the heat, you want it to react quicker. But having a thicker thermal mass makes the heating laggy. When you turn up the heat, it takes time to feel the heat because it has to heat up the thermal mass first. When you turn it off, the thermal mass will continue to radiate heat for a long while after.
So I can't quite understand why the thicker thermal mass is better when it just makes changes less reactive. Can anyone help explain this to me please?
