Blimey JackCol, you're a little bit sensitive aren't you, dear?
I have no axe to grind with you, I can see by your posts that you're a kosher person, and I'm pleased that you've now corrected your recent post by inserting the 'IF' word.
So, I'd now like to have a go at Liam, if that's OK with you? Please feel free to jump to his defence - being the 'righter of wrongs' that you are.......................
Liam: Thank you for the compliment, dear. It's not often that I'm accused of having a superior intellect. So I welcome it - insincere though it might have been.......
Had the O/P expressed the load in kWh, I might have put two and two together. But he didn't - he said that the load was 4.2kW. I did find that odd at the time, but I took him at his word, because I've seen a few commercial dryers of that power - and more, in a domestic situation.
However, since I now know the make and model - where I didn't have that information before, I would estimate the load to be around 2.5kW - comprising a 2 (ish) kW heater plus the motor load.....
So, to the O/P: Plug it in to your 16A boiler circuit. If you have to use an adapter, then keep an eye on it from time to time. Adapters are useful to the DIYer, provided that the limitations of such use are understood.
I don't disagree with the general comments on adapters here, but such devices are still peddled on the market - therefore, they have their place -when used sensibly.
Finally, I'm not in the business of upsetting competent electricians - not deliberately anyway. So I regret that some might think otherwise......
Lucia.
