Hello guys,
A question of best practice if I may?
My 25 year old heat only Glow-worm space saver 60BR mkII supplies a fully pumped open vented system plus indirect cylinder.
My questions are, what should the flow temp be set at roughly when the cylinder stat is set to 60 to heat it the most efficient ish?
The boiler manual says the max output is 82c and I have it set no where near that.
I know the boiler is if off the chart as being inefficient but I need to tune the heating side up but want to know what flow temp I will be working with.
The boiler manual says the pump speed should give an 11c split between flow and return when set to max 82c. I take it that's after all the rads / cylinder have had their take and rad balancing is to 11c diff approx?
I've got some rads to change/move so thought it a good time to learn about the system.
