Change the MCB
NO. getting the extension lead is the better option.
Change the MCB
I have considered that - and, as you will have seen, suggested it as a 'solution' to winston. However, I have 'resisted' it myself because, albeit for no particularly good electrical reason (unless one believes that a circuit's OPD is there to protect things other than cables), I want to avoid any hassle due to eyebrows going up if/when someone comes across a 16A/1mm² lighting circuit in my house in the future! Not a very good reason, I agree!Change the MCB.
Is that the modern day version of "if the fuse blows, but thicker wire/kitchen foil/nail in it until it stops blowing"Change the MCB.
Not really. It's a modern day version of protecting a lighting circuit with an OPD whose rating is appropriate to the CCC of the cable.Is that the modern day version of "if the fuse blows, but thicker wire/kitchen foil/nail in it until it stops blowing"
No, of course not, it is an answer to winston when he decrees that sockets should not be put on 6A circuits.Is that the modern day version of "if the fuse blows, but thicker wire/kitchen foil/nail in it until it stops blowing"
And the point of that would be what, exactly?No, of course not, it is an answer to winston when he decrees that sockets should not be put on 6A circuits.
And the fact that few accessories used on lighting circuits are rated for 16A ?As has been discussed, the tradition/habit of using a 5/6A OPD on a circuit whose cable has a CCC of ≥16A seems to have arisen only for historical reasons.
We've been through this umpteen times before. I don't doubt that a good few people would cite that reason, but they are presumably ones who believe that the circuit's OPD is there for reasons other than protecting the circuit's cable.And the fact that few accessories used on lighting circuits are rated for 16A ?
Are they also ones who can answer EFLI's question?We've been through this umpteen times before. I don't doubt that a good few people would cite that reason, but they are presumably ones who believe that the circuit's OPD is there for reasons other than protecting the circuit's cable.
I doubt they'd think it necessary to answer - they would probably regard it as 'wrong' to have an accessory 'rated at' a current less than the In of the circuit's OPD connected to the circuit, regardless of what currents through the accessory could reasonably be envisaged!Are they also ones who can answer EFLI's question?
I imagine that they would (have to!) be happy with them on a 32A radial - but I'm not sure what they would think about a ring!Do they have 32A sockets?
That should be more accurately re-phrased as "I doubt that they'd have the ability to understand why they should be able to answer it".I doubt they'd think it necessary to answer
- because of their ignorance they would probably regard it as 'wrong' to have an accessory 'rated at' a current less than the In of the circuit's OPD connected to the circuit, regardless of what currents through the accessory could reasonably be envisaged!
