Two appliances in one plug
FeO (which I call ferrous oxide) is now Iron-2-oxide
Fe2O3 (which I call ferric oxide) is now Iron-3-oxide
Is it not Iron II oxide / Iron III oxide, or have they changed to Arabic from the Roman numerals? I am genuinely not being pedantic or flippant!
Oh, you may well be right. I only discovered the chage when trying to help my daughters with GCSE Science, about 15 years ago, and haven't really thought about it much since.
Hang on ... I'll ask Mr Google .... Yes, you're almost right ... it seems to be:
  • Iron (II) oxide and Iron (III) oxide
... but I got the idea right!
Kind Regards, John
Thank god for that! However it's slow to catch on - all this stuff is still packaged as Sodium Bicarbonate, Ferric Chloride, Ferrous Sulphate, Acetic Acid etc and not the not-so-new fangled Sodium Hydrogen Carbonate, Iron (III) Chloride etc etc. I was learning the 'new' valence notation nearly 30 years ago.
I hope 'they' don't rename Aqua Regia - whoever coined that one deserves some credit.
Well, I agree that a lot still seem to bear old-style packaging, but .....
and
I did A-Level Chemistry more years ago than I care to remember (1966, which I fear was 45 years ago!) and there was certainly no hint of the new terminology then.
Kind Regards, John
In WW2, before ring circuits, my grandmother referred to the two sockets in the house as "electric plugs".
These comprised a surface mounted switch with two holes on top. The plug top plugged into the top of the electric plug.
Amen
Lovely devices, beautifully cast with a ceramic based material and a bakelite or brass front to cover the connexions and available in at least 7 formats.
I used to do some work in a local theatre and up until the last 5 years or so there were 6 of the 15A version, each wired with large rubber T&E [7/0.036 or 7/0.044] and 30A breakers [180A total]. These were the supply to the lighting dimmers and regularly ran at 6KW for the duration of a show, I guess they were installed in the 50's [most likely 15A fuses initially] and had therefore given 50 years of trouble free service. They were only removed as new dimmer packs were installed.
They don't make 'm like they used to :)
They'll be changing Finisterre to Fitzroy, Jif to Cif next. And what's all this 'new pence' about? Why can't they just leave things alone? I will be writing a strongly worded letter to Mr Wilson.
Will you also ask him about Marathon bars, Spangles and Opal Fruits, please?
NaHCO3 (which I call sodium bicarbonate - which admittedly was always a bit of a misnomer) is now Sodium Hydrogen Carbonate
The tub in my kitchen cupboard says "Bicarbonate Of Soda" on it. It's usually to be found close by the tub of potassium hydrogen tartrate.
Indeed - we seem to have a 'hybrid' situation at present.
I remember that the bicarb caused some confusion to my daughters in those GCSE days. It seems that they were taught that "Bicarbonate of Soda" was the 'archaic' name for sodium hydrogen carbonate, in much the same was as we were taught similarly about, say, 'Oil of Vitriol' (sulphuric acid)!!
Kind Regards, John.
In WW2, before ring circuits, my grandmother referred to the two sockets in the house as "electric plugs". These comprised a surface mounted switch with two holes on top.
Yep, I remember them. I may even still have one or two hidden away in a dusty corner of my cellar!
:) Tempting though it may be, I don't think one can blame 'plugtop' on that, since the word didn't (AFAIK) appear until a lot later.
Kind Regards, John
And I think we see a similar thing happening with electrical committees with things like RCCB becoming RCD. A pointless change.
RCCB didn't become RCD. An RCCB is one type of RCD. Others include the likes of RCBOs, SRCDs, PRCDs etc.
That's all true, but isn't Paul's point probably that there has been an unnecessary and apparently retrograde change, at least in common usage? Instead of calling an RCCB and RCCB, most people now call it by the family name, RCD - which, as you say, defines what one is talking about less precisely.
Kind Regards, John.
All of which incorporate an RCCB, just in various forms. But even RCCB is a relatively recent term for what for decades was known as a current-operated ELCB.
