- Joined
- 5 Jun 2012
- Messages
- 119
- Reaction score
- 0
- Country
Have connected earth to line by CU to underatke some continuity testing and for testing line switching. I am pretty much taking resistance readings whenever I go along the circuits to see if everything makes sense ... I have arrived at a two way switch, and just wanted to check something - I am pretty sure it is right, but you experts will know ...
At both switches I am taking COM1 and Earth readings under different switching scenarios ... Both switches on, both swiches off, 1st off, second on, and 1st on and second off.
When both are either on or off, I get a COM2/Earth reading only.
When one is on and one is off, I get a COM1/Earth AND a COM2/Earth reading.
I think I get two readings when one is off and the other is on because I get continuity directly through the lamp on one leg and also via the second switch to the lamp the other way ... is that right ????
