I came home last night to find my front garden like a bog. Some work with the spade tracked the issue to a crack in the underground supply pipe to the property after the water meter.
It was after dark when I got to the issue but the pipe work is plastic and not the new style blue MDPE. It is grey pipework approx. 20mm dia.
The crack is adjacent a Tee where the supply splits to a green house and the house. This joint is glued. I no longer really require the supply in the greenhouse.
The Crack is very close to the Tee piece on the leg to said green house. mains in at bottom of "T". green house left and house right. My thoughts are to replace with an elbow.
Not sure what fittings to purchase that will fit this grey pipe work? Obv the joint is wet and 20 inches below ground level so would rather replace than attempt a repair however this may suffice to get water back on.
Any help welcomed.... Pipe size and repair ideas. Would a compression fitting work. Inserts required for the pipework? I have not cut the pipe as yet as the leak is not so bad that we cant turn it on to have showers and fill water bottles etc before isolating again. Due to concrete paths and walls I am restricted in how far I can dig back up the pipe runs. Ideally I was thinking cut tee out, convert to sweeping elbow compression fitting with inserts in existing pipework. As the site was built in the 70's I would assume it could be old imperial size???
Thanks for reading.
Thanks for reading.
