Exactly - and, as I'm sure you understand, that is the reason for many of the questions I've been asking here. One would hope that the training of those in question would enable them to properly understand circuit design, quite apart from 'details' in the regs (which are often only really intended as 'examples'). After all, we're not talking about things which are not compliant with BS7671 - merely things that require a bit of knowledge/thought/work to demonstrate that they are essentially compliant.Unfortunately in our trade there are those that cannot see past BS7671 and the fact that a circuit has been designed outside the scope of it's guidance will send some calling for the electrical police.
Indeed, I'm sure that it would be very easy to justify the design of such a spur in many/most cases - but I again agree that it might 'surpise' some who were only used to standard domestic installations. Appendix 15 of the regs obviously doesn't even attempt to go there, since it only talks about 2.5mm² RFCs.Granted it might throw some working in the domestic scenario, but I come across many commercial ring finals in 4mm² and would not have a problem with a multi socket radial spur from them. (Depending on all other circuit parameters)
Kind Regards, John.
