Do you really believe that you have answered the OP's question in a useful fashion?Rearranging the deck chairs on the titanic is stupid.
Kind Regards, John
Kind Regards, John
I'll leave her to be the judge of that.Yes.JohnW2 said:Do you really believe that you have answered the OP's question in a useful fashion?
That's what I just asked. Maybe he offered, and the offer was declined - or maybe he is the one who is comingf back on Monday (that being the earliest he could do it), or .... ? Only the OP can tell us.How can an electrician detect a hazardous installation and patented leaks and then leave the premises without some form of a repair?
To be fair, we do not have all the facts. For example, we have not been told that the 'second electrician' did not 'make it safe' in some way (until the repair on Monday).... but now a second electrician has found it, has not repaired it and has not 'made it safe', he now becomes accountable. .... My advice to the owner at this time would be to identify which fuse/mcb etc feeds that area and to switch it off. Also put a note on the consumer unit stating not to turn it back on till it has been rectified.
No problem there, Susi1 has done the right thing.hi
I bought a flat a couple of years ago and recently my son was getting electric shocks on the cooker, metal kettle and sink top if he touched two at once. He thought wrongly that it was static but the shocks became worse. I also got a shock touching two appliances at once.
Again no problemGot an electrician to check it over and he informed me that 230volts were being conducted between the appliances if touched similtaneously.
He checked the fuse box and discovered that it hadnt been earthed.
How do you know it was not earthed when that work was done. Your only guessing, I have found where an earth has been broken, and when it has been removed due to change in the water supply pipes. But had this been the case, it would have been highlighted when the new occupiers (you) moved into the home and had the EICR (electrical installation condition report) done, as required with change of occupant.We had electrician put in new plug points and do the electrics on a newly installed kitchen.
He clearly had not checked his work as I was told that if he had done so he would have discovered the fact that it wasnt earthed.
Fact you say "was" I assume now corrected? And as to whom is accountable this account of the death of Emma Shaw shows how it is not always as cut and dried as you think. In that case the plaster, plumber, electrician, electricians mate, and the foreman all made errors, however the court found the foreman to blame, even though he had never been to the home.My concern is that it was a fatality waiting to happen.
Who is accountable for this.
Thank you.
It seems not ....... Fact you say "was" I assume now corrected? ...
However, we haven't been told whether or not the person who detected the 'earthing problem' did anything to 'make things safe' until Monday.Have electrician coming to sort out earthing problem on Monday.....
As said Earthing and Bonding are not the same, I hope he never left without either fixing or isolating sockets not bonded?Have electrician coming to sort out earthing problem on Monday.....
The problem will be locating the original electrician and speaking to second electrician that did the kitchen work. I believed he was properly qualified however i never checked his certification.....i didnt know to do that.
Thank you - that clarifies matters.The electrician who came yesterday said he could not complete the work and would return on monday. He told my son that he could only use one plug point that had been earthed.
This electrician clearly has your safety in mind. Provided you do not use any of the sockets which he has told you not to use, there should be nothing to be nervous about - and it's not long until Monday, when everything will hopefully be sorted out, and made safe.This is making me really nervous.
Indeed - and that's another thing we don't really know about....It looks like a functioning RCD would have prevented all these persistent, small electrocutions? Edit: I take it back, if the leaks are smaller than tripping the RCD but still felt by touch.
