Hey All,
We're planning some major works to our house next Feb and I'm trying to plan out our hot water solution.
We currently have 1 shower room (deluge and hand) and 1 bath with shower rail. These are both on the first floor and we will be doing a loft conversion where we will add another shower.
Currently we run off an Ideal Independent+ C35 to supply the rads and hot water and my wife and I both get up and the same time and cant have a shower since one will be cold (I know! first world problems eh)
Since we're about to have our second child, add an additional shower in the loft and have to relocate the combi with the downstairs renovations anyway I've been looked at switching to unvented cylinders but have a few questions.
A few bits of additional detail that may help:
So a couple of questions and apologies if these are obvious but I've only ever had combis before.
Steve
- I dont know what pressure I get from the mains but a quick 10l bucket and stopwatch test gave me a rough flow rate of 22l/min from the kitchen cold tap.
- All three bathroom/showers are located above/next to each other on one side of the house
- When we moved in about 5 years ago we ran new alkathene pipe from the street to the house, I need to double check but from memory I think it was 25mm
- If my flow rate is 22l/min into the house and I use an unvented cylinder the hot water flow rate can never exceed this since the tank must be replensihed at the same rate otherwise you'd have a vacuum right? So if we ran all three showers at once they would have, for example, 7l/min(ish) flow rate each correct?
- Assuming the above is correct and 22l/min is a pretty decent flow rate into the house and given modern combis can run at 18l/min why would you go to the expense of UC/System boiler if a combi can almost match it? Is it that 18l/min is in ideal circumstances but you rarely get that or is 22l/min into the house is not that good after all?
- Our Combi is about 5 years old and has plenty of life left so could I use this instead of a system boiler as it seems a shame to junk it. In other words could I have an UC heated by electic immersion that is only plumbed into the showers bath and then just use the exiting combi to run the rads and the remaining hot water taps? Be interested to know if this is a stupid idea or not and what the pros/cons might be. (The long term plan would be to replace the combi with a sytem boiler when it dies in X years time but dont know if doing the above locks me into UC/Combi, in other words would I have to buy a specific type of UC that couldnt take its supply from a SB?)
Steve
