Unvented Cylinder with Combi?
Shambolic, I am gobsmaked. Most houses only need 12- 15hw for heating and 2kw for cylinder. I hope you have range rated that boiler.
Ps it's 40kw for hw and 32kw to space heating.
Sham, I was being silly. Even I, not being the top 100, would chuck rated heat input of cylinder coil at it for rapid heating.
Nice hoose
Cham, I was being silly. Even I, not being the top 100, would chuck rated heat input of cylinder coil at it for rapid heating.
Nice hoose
I know I thought you were wearing a Sari there for a moment :ROFLMAO:
Steve 118, an open pipe flow rate of 22 li/min is not the same flow rate that you will get through showers.
A shower needs a residual pressure in the head to provide a high velocity of water from the jet to give that nice tingly feeling on your body. Usually 0.5 to 1.0 bar.
So when considering the flow rate available from the mains to operate showers, you need to measure the dynamic flow rate, for instance the flow rate which still leaves say 1.0 bar pressure in the pipework.
Most people think a 7 li/min shower is rather poor and at least 10 li/min is usually needed for most people to think they have a good shower. When I stay in hotels I sometimes measure the shower flow rate and usually find it is about 12 li/min as a good shower is what makes people like a hotel.
Tony
:):):):) I am going on holiday soon, notes , toothbrush, passport, shorts , weir Guage and wallet , yep will all fit in my back pack, if that shower is not 12 L/min I am coming home
Tony dear boy , I am an Engineer, I work very hard as we are a very busy company, I do not need to take work material on holiday to pretend that I am some kind of plumber or gas engineer, in order to impress some bint in a saree.
