It must be a gift.You seem to be very good at interpreting things the wrong way!
So be it. :shrug:I personally wouldn't call that kind of installation basic plumbing - it may well be straightforward but that is NOT the same thing!
I would have to guess at your motivation. Is it because the folklore about it being a "potential bomb" (sic.) applies only if it's wrongly installed?WHY would I want to install a potential hotwater bomb into my own home?
That's a bit like saying that the first time you would be discovered DUI is when you mow down another road user. The reduced probability of discovery does nothing to make the crime any less criminal.However if I did probably the only point at which any one would realise and I could be prosecuted for having done so would be when I was scalded and homeless!
That's covered by the notifiable element, therefore I've already mentioned it. If you keep denying that it applies, then I'll keep correcting you. If you consider that my persistent correction of your error is "going on about it", then I make no apologies for that, because the bigger picture is that serious errors need to be pointed out to any reader who (against all odds) knows less than you do.Since you keep going on about it why have you not mentioned that is a requirement to ensure you local council is aware of the installation and that it requires building approval as well?
If you'd prefer people to assume that your claimed caution is the same thing as knowing what's actually dangerous and actually illegal, then you're posting on the wrong forum.Surely the very question I asked indicated I was quite cautious -can I drain and refill the cylinder myself?
If you'd prefer people to interpret your words in the way that you mean them, then you should write your words unambiguously. In this context I can't think of a more woolly term than "basic plumbing" (other than "basic work" perhaps).
