It is plain you can't understand something so simple.
The only thing you need to understand here is that BigBurner is Dr Drivel operating under another name, he is posting his usual ill-considered drivel, he is simple and he cannot grasp the many failings inherent in his half-wit schemes.
For example
Feeding pre-warmed or hot water back into the cold water feed connection on a combi assumes that the cold inlet components on the combi are rated for hot water; many of them aren't.
Fit a bronze pump on the pipe from the bottom of the cylinder pumping into the combi.
The conection for the bronze pump would have to be from the bottom of the cylinder. The only connection there is usually the cold feed.You'd be pumping from the cold feed back into the cold feed; impossible. You will also have entrained limescale particles in hard-water areas; this will knacker your combi plate heat exchanger and your canned rotor bronze pump in a short time.
It also assumes that a bronze canned rotor pump will produce enough head to produce the minimum flow rate through the high hydraulic resistance of the combi plate heat exchanger.
The major problem is that most combis use a diaphragm-actuated diverter valve to fire the combi on a hot water demand. This only works when a tap is turned on. Putting in a re-circulation system, as Drivel recommends, will not operate the diverter valve and will not make the combi fire up.
The man's a fool; ignore everything he recommends.
As mentioned above, put in an indirect unvented system with an S-plan plus control/wiring system. This works, I've done it.
