My Hager CU is some 20 years old with both the RCD and MCB slots fully occupied. I'm planning to install an illuminated wall cabinet in a new shower room. Although it will be located beyond zone 2, I understand this will need to be connected to an RDC or similar. As the cabinet is to be wired into the lighting circuit (and as an earlier installed cabinet in the main bathroom runs on the same circuit), my thoughts are to replace this circuit's 6a MCB with a single pole B type RCBO.
Those that I've seen on line show both live and neutral terminal at the top, with the buzbar connecting screw at the bottom. Also, I notice that some come with a blue (neutral) flex and a white flex already installed.
I'd be grateful for clarification on the wiring of such RCBos. Normally, an MCB has the live outward feed at the top, with the neutral running to the block on that side of the CU, but how do you connect an RCBO with or without flexes already attached?
Also, does anyone know of a 'compact' B type RCBO supplier?
Finally, I see references to A curves and B curves. Is this an alternative way of describing A and B types?
Many Thanks
Many Thanks
