The gas meter is in a cabinet just outside our kitchen. The pipe runs 3 meters in a straight line to the boiler through a hole in a wall and raises 1.5 meters vertically from the floor to the boiler inself.
Yes, it's a copper 22mm pipe. This was suggested by a sales person who said the installer would be able to advise exactly whether this needs to be increased or not. He also said that it might be the case with WB 25SI or CDi 28 Compact but not Vaillant's.
Trying hectically right now to get the last quote in. Just sent pictures to an installer who I liked very much because of the way he explained things. He leaned a bit towards Vaillant’s but not much. He is also accredited WB and Vaillant installer which is good.
Choosing a boiler is one thing but getting the right installer is more important. Unfortunately, there is no one to get a recommendation from, so trying to do as much home work as possible.
Oh great! One more new thing to investigate - whether to get a boiler with a stainless steel heat exchanger or an aluminium one. I did not reliase they had heat exchangers made from different materials and that it might be important.
Will do a quick search of the forum posts. Thanks for mentioning.
I am pretty much decided on Vaillant ecoTEC 831 now and just hope the installer will be good. Waiting for the final quote right now.
Thanks to all who reassured about overall quality of both boilers. I feel much more confident going ahead now.
