- Joined
- 27 Jan 2008
- Messages
- 24,556
- Reaction score
- 2,812
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I was always lead to believe since oil and gas costs less than electric, there was no debate, oil or gas is cheaper for heating DHW.
However when I got solar panels, I also go an iboost+ and moved over to heating DHW with surplus electric before it is exported, and this time of year I would normally check oil level which was normally below half full, i.e. below the bracing bar by a few inches, this year around the same amount above the bar. This does not prove anything, but it did do something dangerous, it made me start thinking.
Winter I can't stop the oil heating the DHW, and would not want to, as there is no real surplus of sun, and any heat escaping from pipes, is heating the house, so not wasted. Debate is summer only.
So on a C Plan with I think 22 mm pipe work, boiler is two floors lower than hot water tank, pipe work not lagged, and no access to lag it, no thermostat in/on tank so water heated by running boiler 4 times a week for ½ hour each time, it actually runs for 20 minutes before the return water temperature turns off the boiler.
So it would seem 19 kW x 4 / 7 / 3 = 3.6 kWh per day average to keep DHW hot with oil, I looked a few minutes ago and the iboost+ says saved 0.24 kWh today, since not midday (1 pm) yet I would assume around 0.5 kWh per day, so it seems I am using around 7 times the energy to heat the DHW with oil as to with electric. This seems to be where the argument oil/gas v electric falls over.
So electric heats around top 9" of water in the tank, and the oil heats the whole tank, but unless having a bath, the 9" is good enough. If I used gas my smart meter would tell me exactly how much gas used, but with oil, I can't really measure accurately enough. But it seems clear it is not a case of saying off peak electric costs 8.95p per kWh and oil costs 5p per kWh as more oil is used to heat up more of the tank plus the pipework.
So 7 x 5 = 35p per kWh v 31.31p per kWh for peak electric, so even without having an off peak supply the maths seem to show heating with resistive electric is likely no more expensive to using gas or oil.
However I remember around 15 years ago now, my daughter turned down the water temperature for DHW in her house, to save on gas used, this resulted in gas temp being lower than electric temp set, so electric heated her DHW resulting in a huge bill. However did not look at how much gas bill went down. But this seems to show electric DHW costs more than gas DHW.
Clearly not every house has the DHW tank three floors higher than the boiler, but even my dads house, the boiler was in kitchen back of house, and DHW tank in space formed by stairs at front of the house, and the distance resulted in 32 mm pipe work. When replaced with a combi boiler then distance kitchen tap to boiler very much reduced, from the kitchen tap to hot water tank, so I am sure gas in that case was cheaper, and once a combi boiler fitted no real option but use gas/oil. I am talking about a system boiler with a hot coil heating the DHW tank or an immersion heater in same tank.
So if one has a C Plan boiler system, is it worth running it in summer?
