Using a combi tester???
29 Oct 2007
A very simple/numbty question, but just to put my mind at ease.
When using a combi test or multimeter, I presume it is ok to test between live and neutral, l & E, E & N or different live to live on 3 phase. Its not going to blow up/affect the circuit i'm testing is it?.
What are you trying to do?
You shouldn't really be using anything without GS38 compliant leads and probes on a live circuit... those mutimeters go bang if you've left them on the wrong range :LOL:
simply using a combi tester (with probes <4mm) (or multimeter on correct setting) to test what voltage is between the two wires
Are we talking about one of these: http://www.pat-training.co.uk/combitest_part_p_tester.htm ?
Then yes, as long as its got a function for measuring supply voltage then you can use it, bit bulky for that though, one of these would be perhaps better: http://www.maplin.co.uk/Module.aspx?C=SO&U=strat320&T=sitenew&ModuleNo=46245 (note, only UK spec version is GS38 compliant!)
Ordinary multimeter should be kept away from live circuit unless you have GS38 test leads for it!, one day you will leave it on basic continuity/bleep range and forget about it until it goes bang!
nope not a multi tester, it is one of the little combi tester with GS38 leads.
I've only tested dead circuit before after I've installed it for insualtion and continuity, then my boss would connect up to supply, and so was alittle paranoid about simply testing for a voltage in an existing circuit, as only been training/working for last month.
But thanks for the clarity, I can use the combi tester between any inputs (l,N,E) for their voltage.
Cheers
Do still bear in mind, that while fused leads with the correct fuse in should stop the insument exploding in a fireball in your face should you get it wrong, if you **** up, don't expect it to work again!, a lot of the older loop testers are not for phase->phase use, etc
I'm still not sure what instrument we are actually talking about by 'combi test' here?
Ground down [/pendant]
Still doesn't give you fused leads, but still at least you can't leave it on the wrong setting!
I'd still prefer something that was made to meet GS38 properly though, though I'll conceed that its a lot better than a multimeter!
