vailant echo tech plus
21 Nov 2012
Hi I have a valiant echo tech plus and the pressure keeps going into red. By the end of the week I have to take water out of the central heating system. I have checked the taps below boiler and they are closed not sure how to correct problem.
Why was the diverter changed? Whether it's costly depends on what the problem is. Make sure your filling loop is turned off properly and disconnect it to check it's not passing
I have valiant gold cover for the boiler . The heating keep.on going on when The water was heating heating up. And there was a leak under the boiler. The valiant guy came twice and on the second time noticed the diverter was leaking so he changed it since then he presurre bar keep on going into the red. The first time it happened the heating stopped working and the boiler had a puddle under it. Thinking it the diverter again I called them back and all he could find is water on the left hand side and he puta clip on something. now when the pressure bar goes into red there is not .puddle the heating stops working
