Ok stored water temp this morning was 62c mains is 12c (figures I doubt widly different from the other day).
Pump still not turned up!
Had a spare 15mins before work and run the following test d.0 set to 30 target temp 75
CH set to on, HW off (note I have the same symptoms on CH as with HW when d.0 set to 11).
time d.40 D.41
0:17 41 30
0:22 44 28
0:30 43 27
0:36 42 27
0:43 41 27
0:49 41 27
1:09 50 28 boiler now running at d.0 perceived by fan noise
1:17 51 28
1:24 51 28
1:29 51 28
1:35 52 29
1:41 52 29
1:47 52 29
1:55 53 30
2:01 53 30
2:07 53 30
2:15 54 31
2:25 54 31
2:31 55 32
2:37 55 32
2:43 55 33
2:49 56 33
2:58 56 34
3:02 57 34
3:10 57 34
3:14 58 35
3:21 58 35
3:26 59 36
3:32 59 36
3:41 59 37
3:47 60 37
3:57 61 38
4:20 62 40
4:27 63 40
4:32 63 40
4:41 64 41
4:46 64 42
4:55 65 42
5:02 65 41
5:07 66 43
5:14 66 43
5:21 67 44
5:27 67 44
5:34 68 45
5:40 68 45
5:46 68 46
5:51 69 46
6:05 69 47
6:11 70 47
6:18 70 48
6:26 71 48
6:31 71 49
6:37 72 49
6:43 72 49
6:49 72 50
6:57 73 50
7:02 73 51
7:07 74 51
7:12 74 51
7:18 74 52
7:27 75 52
7:34 75 53
7:40 75 53
7:53 75 54
8:15 75 55
8:21 75 56
8:31 75 56
9:10 75 58 boiler modulating
9:32 75 60
9:55 75 61
At this point I reduced target temp as I did not have much more time left
On refire the boiler fired at a reduced fan noise compared to when it was running @ d.0 setting and then tried to ramp up to d.0 and then overshot and boiler cycled. Obviously this what not quite a real word scenario as I had moved target temp by quite an amount due to time constraints. But did prove I believe that d.0 is being ignored during initial x seconds.
thanks
time d.40 D.41
0:17 41 30
0:22 44 28
0:30 43 27
0:36 42 27
0:43 41 27
0:49 41 27
1:17 51 28
1:24 51 28
1:29 51 28
1:35 52 29
1:41 52 29
1:47 52 29
1:55 53 30
2:01 53 30
2:07 53 30
2:15 54 31
2:25 54 31
2:31 55 32
2:37 55 32
2:43 55 33
2:49 56 33
2:58 56 34
3:02 57 34
3:10 57 34
3:14 58 35
3:21 58 35
3:26 59 36
3:32 59 36
3:41 59 37
3:47 60 37
3:57 61 38
4:20 62 40
4:27 63 40
4:32 63 40
4:41 64 41
4:46 64 42
4:55 65 42
5:02 65 41
5:07 66 43
5:14 66 43
5:21 67 44
5:27 67 44
5:34 68 45
5:40 68 45
5:46 68 46
5:51 69 46
6:05 69 47
6:11 70 47
6:18 70 48
6:26 71 48
6:31 71 49
6:37 72 49
6:43 72 49
6:49 72 50
6:57 73 50
7:02 73 51
7:07 74 51
7:12 74 51
7:18 74 52
7:27 75 52
7:34 75 53
7:40 75 53
7:53 75 54
8:15 75 55
8:21 75 56
8:31 75 56
9:32 75 60
9:55 75 61
thanks
