Because you will never get the balancing right if the boiler is not properly set up for the available rads output.Why are people pointing to the boiler, when the fault is clearly a CIRCULATION/BALNCING ISSUE
What the F**K has boiler output got to do with it the OP took out a 19Kw boiler and replaced it with a 6-31Kw FULLY MODULATING unit so lets start looking at system circulation perleese
You have hit the nail on the head; it's all about the first fire. The problem is that every time the boiler restarts it is treated as a first fire so, if the water gets heated up faster than the rads can dissipate the heat, the water temperature will rise to quickly and the boiler thermostat will kick in.Range rating helps the boiler perform better by capping its maximum on first fire but not doing it will not cause any problems.
Now who's talking theory? I don't know what the reaction time of the typical modulating burner is, but I bet it's not instantaneous - after all it is a mechanical device.an intelligent pre-mix burner as used on vaillant and other boilers if the water in the boiler was rising rapidly, the boiler would modulate down,
But is it modulating down to 8kw or continually cycling?sambotc said:My heat output equals about 8kw and I have/had no problems using factory setting (MAX@24kw)
The boiler does not cut in and out unless it is the CM927 telling it to do so, all my rad's get hot at the same rate because there is sufficent circulation to do so.
Sam
