Thank you very much for that. Annoying as my other systems have never had that limitation. I had hoped there would be something on the VRC 470f controller under the installer level settings that I could change.
I replaced the boiler with a Vaillant, but originally running on my old control system. The old boiler just had a single flow temperature setting, irrespective of supplying CH or HW. With those old controls, the new Vaillant only permitted one flow setting, because it could know what system it was supplying.
Within a month, I installed and upgraded to the VRC 470f with remote out door sensor. Once installed, I found it could only do one or the other.
It was also my first system with this limitation too and I was a bit surprised, though in practise it is not a big problem to have the CH not available for the 20 minutes worst case it takes to reheat the cylinder. When I first set it up, I had it heat the water just at the times it would normally be used - a single 30 minute boost at 4pm, then use the manual boost for the occasions when a bath was needed. That scheme made the loss of CH noticeable, so I now have it set to keep the cylinder hot from 10am to 6pm. The brief boiler occasional runs to reheat the cylinder are not then noticed.
