CH works fine. DHW works when CH is on. No DHW when CH is off.
White rocker arm isn't pushing down the microswitch when DHW is called for. Diaphragm looks fine but I've replaced it anyway to rule that out but still the rocker arm won't budge.
If I have the water section open I can push up on the "plunger" (the flat plastic disc with the thin metal rod sticking out of it) that the diaphragm would normally operate but this too doesn't move the white rocker arm.
Any ideas as to where the fault lies? Is it time for a new diverter valve?
Help greatly appreciated.
Cheers
Rich
Cheers
Rich
